12
返回列表 发新帖
楼主: easyearn
[Windows VPS] 求测PING值!
发表于 2012-7-2 22:28:25 来自手机 | 只看该作者
发表于 2012-7-2 22:28:31 | 只看该作者
直接路由器上ping的郑州联通
ping输出结果:
PING 76.191.96.2 (76.191.96.2): 56 data bytes
64 bytes from 76.191.96.2: seq=0 ttl=50 time=310.610 ms
64 bytes from 76.191.96.2: seq=1 ttl=50 time=317.297 ms
64 bytes from 76.191.96.2: seq=2 ttl=50 time=318.626 ms
64 bytes from 76.191.96.2: seq=3 ttl=50 time=310.544 ms
--- 76.191.96.2 ping statistics ---
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 310.544/314.269/318.626 ms
ping输出结果:
PING 63.223.125.2 (63.223.125.2): 56 data bytes
64 bytes from 63.223.125.2: seq=0 ttl=114 time=280.293 ms
64 bytes from 63.223.125.2: seq=1 ttl=114 time=284.393 ms
64 bytes from 63.223.125.2: seq=2 ttl=114 time=253.092 ms
64 bytes from 63.223.125.2: seq=3 ttl=114 time=265.305 ms
--- 63.223.125.2 ping statistics ---
round-trip min/avg/max = 253.092/270.770/284.393 ms
ping输出结果:
PING 4.71.152.18 (4.71.152.18): 56 data bytes
64 bytes from 4.71.152.18: seq=0 ttl=241 time=254.359 ms
64 bytes from 4.71.152.18: seq=1 ttl=241 time=253.495 ms
64 bytes from 4.71.152.18: seq=2 ttl=241 time=251.663 ms
64 bytes from 4.71.152.18: seq=3 ttl=241 time=253.119 ms
--- 4.71.152.18 ping statistics ---
round-trip min/avg/max = 251.663/253.159/254.359 ms
ping输出结果:
PING 63.223.82.11 (63.223.82.11): 56 data bytes
64 bytes from 63.223.82.11: seq=0 ttl=53 time=339.486 ms
64 bytes from 63.223.82.11: seq=1 ttl=53 time=336.416 ms
64 bytes from 63.223.82.11: seq=2 ttl=53 time=345.990 ms
64 bytes from 63.223.82.11: seq=3 ttl=53 time=331.578 ms
--- 63.223.82.11 ping statistics ---
round-trip min/avg/max = 331.578/338.367/345.990 ms
参与人数 1威望 +4 收起 理由
easyearn + 4 赞一个!
发表于 2012-7-2 22:31:16 | 只看该作者
哈尔滨联通
C:\Users\Administrator>ping 76.191.96.2
正在 Ping 76.191.96.2 具有 32 字节的数据:
来自 76.191.96.2 的回复: 字节=32 时间=271ms TTL=50
来自 76.191.96.2 的回复: 字节=32 时间=273ms TTL=50
来自 76.191.96.2 的回复: 字节=32 时间=270ms TTL=50
76.191.96.2 的 Ping 统计信息:
往返行程的估计时间(以毫秒为单位):
    最短 = 270ms,最长 = 273ms,平均 = 271ms
C:\Users\Administrator>ping 63.223.125.2
正在 Ping 63.223.125.2 具有 32 字节的数据:
来自 63.223.125.2 的回复: 字节=32 时间=306ms TTL=114
来自 63.223.125.2 的回复: 字节=32 时间=303ms TTL=114
来自 63.223.125.2 的回复: 字节=32 时间=302ms TTL=114
来自 63.223.125.2 的回复: 字节=32 时间=305ms TTL=114
63.223.125.2 的 Ping 统计信息:
往返行程的估计时间(以毫秒为单位):
    最短 = 302ms,最长 = 306ms,平均 = 304ms
C:\Users\Administrator>ping 4.71.152.18
正在 Ping 4.71.152.18 具有 32 字节的数据:
来自 4.71.152.18 的回复: 字节=32 时间=288ms TTL=240
来自 4.71.152.18 的回复: 字节=32 时间=289ms TTL=240
来自 4.71.152.18 的回复: 字节=32 时间=291ms TTL=240
来自 4.71.152.18 的回复: 字节=32 时间=292ms TTL=240
4.71.152.18 的 Ping 统计信息:
往返行程的估计时间(以毫秒为单位):
    最短 = 288ms,最长 = 292ms,平均 = 290ms
C:\Users\Administrator>ping 63.223.82.11
正在 Ping 63.223.82.11 具有 32 字节的数据:
来自 63.223.82.11 的回复: 字节=32 时间=313ms TTL=50
来自 63.223.82.11 的回复: 字节=32 时间=314ms TTL=50
来自 63.223.82.11 的回复: 字节=32 时间=308ms TTL=50
来自 63.223.82.11 的回复: 字节=32 时间=301ms TTL=50
63.223.82.11 的 Ping 统计信息:
往返行程的估计时间(以毫秒为单位):
    最短 = 301ms,最长 = 314ms,平均 = 309ms
参与人数 1威望 +3 收起 理由
easyearn + 3 赞一个!
发表于 2012-7-2 22:42:52 | 只看该作者
来自 76.191.96.2 的回复: 字节=32 时间=193ms TTL=50
来自 76.191.96.2 的回复: 字节=32 时间=194ms TTL=50
往返行程的估计时间(以毫秒为单位):
    最短 = 193ms,最长 = 194ms,平均 = 193ms
来自 63.223.125.2 的回复: 字节=32 时间=191ms TTL=114
来自 63.223.125.2 的回复: 字节=32 时间=187ms TTL=114
来自 63.223.125.2 的回复: 字节=32 时间=186ms TTL=114
往返行程的估计时间(以毫秒为单位):
    最短 = 186ms,最长 = 191ms,平均 = 187ms
请求超时。
来自 4.71.152.18 的回复: 字节=32 时间=319ms TTL=242
来自 4.71.152.18 的回复: 字节=32 时间=332ms TTL=242
来自 4.71.152.18 的回复: 字节=32 时间=374ms TTL=242
    数据包: 已发送 = 4,已接收 = 3,丢失 = 1 (25% 丢失),
往返行程的估计时间(以毫秒为单位):
    最短 = 319ms,最长 = 374ms,平均 = 341ms
来自 63.223.82.11 的回复: 字节=32 时间=202ms TTL=54
往返行程的估计时间(以毫秒为单位):
    最短 = 202ms,最长 = 202ms,平均 = 202ms
南宁电信
参与人数 1威望 +3 收起 理由
easyearn + 3 赞一个!
GMT+8, 2026-4-15 15:32 , Processed in 0.065202 second(s), 14 queries , Gzip On, MemCache On.
