楼主: 天权璇玑
可怕,设置调节 swap 功能竟然鸽了 4 个月
 楼主| 发表于 2023-11-22 16:29:00 | 只看该作者
念念不忘 发表于 2023-11-22 16:13
我尝试你的内核新功能时,在”apt install linux-xanmod-lts-x64v3 -y“,提示E: Unable to locate package ...
需要单独安装xanmod,具体我稍后放出
42#
发表于 2023-11-23 13:30:25 | 只看该作者
W: GPG error: http://deb.xanmod.org releases InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 86F7D09EE734E623
E: The repository 'http://deb.xanmod.org releases InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
aws_sg
43#
 楼主| 发表于 2023-11-23 13:38:48 | 只看该作者
念念不忘 发表于 2023-11-23 13:30
W: GPG error: http://deb.xanmod.org releases InRelease: The following signatures couldn't be verifie ...
写了一个小教程,具体参见:https://github.com/leitbogioro/Tools/blob/master/README.md#little-tutorial-installing-xanmod-on-debian
安装前建议把 bbr 装上:
  1. bash InstallNET.sh --bbr
顺序是先用脚本安装标准 Debian 环境并开启 bbr ,然后再按教程安装 XanMod
44#
发表于 2023-11-23 13:48:22 | 只看该作者
天权璇玑 发表于 2023-11-23 13:38
写了一个小教程,具体参见:https://github.com/leitbogioro/Tools/blob/master/README.md#little-tutori ...
这个我开启了,
45#
 楼主| 发表于 2023-11-23 13:54:10 | 只看该作者
再重装一次,根据教程安装 xanmod ,我在 Debian 11 12 上测试过,可以顺利安装,仅限 amd64 处理器
46#
发表于 2023-11-23 13:56:55 | 只看该作者
root:~# wget -qO - https://dl.xanmod.org/archive.key | sudo gpg --dearmor -o /usr/share/keyrings/xanmod-archive-keyring.gpg
File '/usr/share/keyrings/xanmod-archive-keyring.gpg' exists. Overwrite? (y/N) y
gpg: no valid OpenPGP data found.
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package linux-xanmod-lts-x64v3
47#
发表于 2023-11-23 13:58:41 | 只看该作者
uname -a
Linux ip--cloud-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.55-1 (2023-09-29) x86_64 GNU/Linux
48#
发表于 2023-11-23 13:59:52 | 只看该作者
念念不忘 发表于 2023-11-23 13:56
root:~# wget -qO - https://dl.xanmod.org/archive.key | sudo gpg --dearmor -o /usr/share/keyrings/xan ...
过程,bash InstallNET.sh --bbr
然后按照你教程里面的那些命令,依次执行,上面是我途中遇到的错误
49#
发表于 2023-11-23 14:11:11 | 只看该作者
关于你的新功能,最近我都遇到一个问题。
用那个装第三方内核的命令之后,不管内核是否成功(虽然实际上没成功过),当我再次运行bash InstallNET.sh --bbr命令的时候,脚本无法运行,提示缺少依赖(没运行那个之前,不管怎么d都没问题)
,而且依赖还装不行去(可能我技术不行)
  1. # Check Dependence
  2. [ok]                awk
  3. [ok]                basename
  4. [ok]                cat
  5. [ok]                cpio
  6. [ok]                curl
  7. [ok]                cut
  8. [ok]                dirname
  9. [ok]                file
  10. [ok]                find
  11. [ok]                grep
  12. [ok]                gzip
  13. [ok]                iconv
  14. [ok]                ip
  15. [ok]                lsblk
  16. [ok]                openssl
  17. [ok]                sed
  18. [ok]                wget
  19. [Not Install]        xz
  20. [Error] Please use 'apt-get' or 'yum / dnf' install it.
50#
 楼主| 发表于 2023-11-23 14:34:11 | 只看该作者
导入 gpg 密钥的那一步如果不按教程来,会出现错误,导致整个 apt 更新源失败,无法安装 xz,我把校验 xz  依赖部分删掉吧,你重下脚本安装
这是安装了 xanmod 的 Debian 11 重装前,重装时选择开启 bbr: --bbr
运行命令:
  1. bash InstallNET.sh --motd --bbr
这是进新 Debian 12 系统后安装 xanmod 重启后的状态,可以看到 bbr 已开启,xanmod 也安装完成:
GMT+8, 2026-4-15 02:28 , Processed in 0.058679 second(s), 6 queries , Gzip On, MemCache On.
