楼主: zxxx
InterServer 大盘鸡磁盘速度测试
发表于 2023-3-20 09:14:57 | 只看该作者
惊呆了老铁
32#
发表于 2023-3-20 09:32:11 | 只看该作者
小猪佩奇 发表于 2023-3-19 19:18
能跑完测试已经很不容易了,现在大盘鸡每天重启一次,直接进不了系统敢信 ...
我擦一样啊..
33#
发表于 2023-3-20 09:45:29 | 只看该作者
  1. Mon Mar 20 02:36:21 CET 2023
  2. Basic System Information:
  3. ---------------------------------
  4. Uptime     : 2 days, 17 hours, 10 minutes
  5. Processor  : AMD EPYC 7571 32-Core Processor
  6. CPU cores  : 1 [url=home.php?mod=space&uid=175]@[/url] 2200.000 MHz
  7. AES-NI     : ✔ Enabled
  8. VM-x/AMD-V : ✔ Enabled
  9. RAM        : 989.9 MiB
  10. Swap       : 0.0 KiB
  11. Disk       : 503.6 GiB
  12. Distro     : Ubuntu 18.04.6 LTS
  13. Kernel     : 4.11.8-041108-generic
  14. VM Type    : KVM
  15. Basic Network Information:
  16. ---------------------------------
  17. Protocol   : IPv4
  18. ISP        : The Infrastructure Group B.V.
  19. ASN        : AS60404 Liteserver
  20. Host       : Liteserver DRN VPS
  21. Location   : Amsterdam, North Holland (NH)
  22. Country    : Netherlands
  23. fio Disk Speed Tests (Mixed R/W 50/50):
  25. Block Size | 4k            (IOPS) | 64k           (IOPS)
  26.   ------   | ---            ----  | ----           ----
  27. Read       | 12.23 MB/s    (3.0k) | 139.97 MB/s   (2.1k)
  28. Write      | 12.23 MB/s    (3.0k) | 140.71 MB/s   (2.1k)
  29. Total      | 24.46 MB/s    (6.1k) | 280.68 MB/s   (4.3k)
  30.            |                      |
  31. Block Size | 512k          (IOPS) | 1m            (IOPS)
  33. Read       | 345.13 MB/s    (674) | 398.26 MB/s    (388)
  34. Write      | 363.47 MB/s    (709) | 424.79 MB/s    (414)
  35. Total      | 708.61 MB/s   (1.3k) | 823.05 MB/s    (802)
  36. iperf3 Network Speed Tests (IPv4):
  37. ---------------------------------
  38. Provider        | Location (Link)           | Send Speed      | Recv Speed      | Ping
  39. -----           | -----                     | ----            | ----            | ----
  40. Clouvider       | London, UK (10G)          | 429 Mbits/sec   | 604 Mbits/sec   | 6.98 ms
  41. Scaleway        | Paris, FR (10G)           | 436 Mbits/sec   | 610 Mbits/sec   | 11.2 ms
  42. NovoServe       | North Holland, NL (40G)   | busy            | busy            | 2.40 ms
  43. Uztelecom       | Tashkent, UZ (10G)        | 738 Mbits/sec   | 192 Mbits/sec   | 96.2 ms
  44. Clouvider       | NYC, NY, US (10G)         | 614 Mbits/sec   | 209 Mbits/sec   | 153 ms
  45. Clouvider       | Dallas, TX, US (10G)      | busy            | 342 Mbits/sec   | 118 ms
  46. Clouvider       | Los Angeles, CA, US (10G) | 651 Mbits/sec   | busy            | 151 ms
  47. Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems).
  48. YABS completed in 7 min 59 sec
34#
发表于 2023-3-20 10:09:26 | 只看该作者
万里长城万里长 发表于 2023-3-19 19:39
你好歹还能登录。我**ssh都连不上
我也登不上,30次看能不能上一次。。。
35#
发表于 2023-3-20 10:23:26 | 只看该作者
zxxx 发表于 2023-3-20 09:13
或许,可能,总之重装一下,从k到m了
还真是。。。重装后IO限制在100了,比几百K强
36#
 楼主| 发表于 2023-3-20 12:46:18 | 只看该作者
这个那个节点
37#
发表于 2023-3-20 12:57:34 来自手机 | 只看该作者
发个测试看下。我跑的结果是1m的块,读50多MBps,写60多MBps,总共120MBps。不知道是否算正常了。
38#
发表于 2023-3-20 13:09:59 | 只看该作者
  1. ----------------------------------------------------------------------
  2. I/O Speed(1st run) : 86.2 MB/s
  3. I/O Speed(2nd run) : 73.9 MB/s
  4. I/O Speed(3rd run) : 95.6 MB/s
  5. I/O Speed(average) : 85.2 MB/s
  6. ----------------------------------------------------------------------
诶,至少能用吧,这个价格也就当个BT盒子了
39#
 楼主| 发表于 2023-3-20 13:16:33 | 只看该作者
  1. dd if=/dev/zero of=/tmp/256M1.img bs=4k count=64k oflag=dsync
  2. dd if=/dev/zero of=/tmp/256M2.img bs=64k count=4k oflag=dsync
  3. dd if=/dev/zero of=/tmp/256M3.img bs=512k count=512 oflag=dsync
  4. dd if=/dev/zero of=/tmp/256M4.img bs=1M count=256 oflag=dsync
  1. 65536+0 records in
  2. 65536+0 records out
  3. 268435456 bytes (268 MB, 256 MiB) copied, 702.513 s, 382 kB/s
  4. 4096+0 records in
  5. 4096+0 records out
  6. 268435456 bytes (268 MB, 256 MiB) copied, 48.2626 s, 5.6 MB/s
  7. 512+0 records in
  8. 512+0 records out
  9. 268435456 bytes (268 MB, 256 MiB) copied, 7.95813 s, 33.7 MB/s
  10. 256+0 records in
  11. 256+0 records out
  12. 268435456 bytes (268 MB, 256 MiB) copied, 4.08779 s, 65.7 MB/s
40#
发表于 2023-3-20 14:26:27 | 只看该作者
太惨烈了,还不如买HH的2T了
GMT+8, 2026-4-17 02:53 , Processed in 0.059018 second(s), 8 queries , Gzip On, MemCache On.
