123
返回列表 发新帖
楼主: Xiaomage2333
AZ全面拔线?
发表于 2023-1-25 16:05:17 | 只看该作者
最新消息:电信又接回去了,只不过绕新加坡了,香港直连无了。
最最信消息:电信又绕日本了,不绕新加坡了,香港直连依旧GG。
最最最信消息:香港直连恢复了,全剧终。
22#
 楼主| 发表于 2023-1-25 16:06:55 | 只看该作者
yqnnko 发表于 2023-1-25 15:58
AZ出问题了吧 用日本的机器mtr过去也是绕路的 何况现在还只是去程绕路
应该是的 我上面的smokeping提示到google cloudflare vultr linode都出现了问题 GitHub刚刚爆炸了,可能也是受累于az.
23#
发表于 2023-1-25 16:10:36 | 只看该作者
先不慌一手,现在AWS 日本 到 AZ 日本/HK 的路由甚至都绕
24#
发表于 2023-1-25 16:12:20 | 只看该作者
香港-outlook
日本-outlook
25#
发表于 2023-1-25 16:31:51 | 只看该作者
江苏电信
来自 20.187.** 的回复: 字节=32 时间=56ms TTL=47
来自 20.187.*** 的回复: 字节=32 时间=55ms TTL=47
江苏移动
64 bytes from 20.187.*** seq=2 ttl=44 time=76.544 ms
64 bytes from 20.187.***: seq=3 ttl=44 time=75.904 ms
表示体验良好
26#
发表于 2023-1-25 18:23:22 | 只看该作者
COMMUNICATION:
Starting at 07:05 UTC on 25 January 2023, customers may experience issues with networking connectivity, manifesting as network latency and/or timeouts when attempting to connect to Azure resources in Public Azure regions, as well as other Microsoft services including M365, PowerBI.
We've determined the network connectivity issue is occurring with devices across the Microsoft Wide Area Network (WAN). This impacts connectivity between clients on the internet to Azure, as well as connectivity between services in datacenters, as well as ExpressRoute connections. The issue is causing impact in waves, peaking approximately every 30 minutes.
Current Status: We have identified a recent WAN update as the likely underlying cause, and have taken steps to roll back this update. Our latest telemetry shows signs of recovery across multiple regions and services, and we are continuing to actively monitor the situation.
27#
发表于 2023-1-25 18:57:41 | 只看该作者
来自 104.208.*.* 的回复: 字节=32 时间=9ms TTL=50
104.208.*.* 的 Ping 统计信息:
往返行程的估计时间(以毫秒为单位):
    最短 = 9ms,最长 = 10ms,平均 = 9ms
GMT+8, 2026-4-24 17:40 , Processed in 0.070454 second(s), 10 queries , Gzip On, MemCache On.
