楼主: 在7楼
[经验] 【开源】你们要的一键脚本部署naiveproxy
发表于 2023-1-7 23:20:18 | 只看该作者
太奇怪了,重装了还是不行,连不上
tail: cannot open 'tail' for reading: No such file or directory
要不你创建一个测试用的用户和密码,私信我,我来用我的client测一下?  发表于 2023-1-8 00:34
53#
发表于 2023-1-9 15:30:15 | 只看该作者
Formate the Caddyfile
Start server
2023/01/09 07:29:25.635        INFO        using provided configuration        {"config_file": "/data/Caddyfile", "config_adapter": ""}
Error: adapting config using caddyfile: parsing caddyfile tokens for 'route': /data/Caddyfile:14 - Error during parsing: parsing caddyfile tokens for 'forward_proxy': /data/Caddyfile:5 - Error during parsing: Wrong argument count or unexpected line ending after 'jjpssl'
Error: caddy process exited with error: exit status 1
什么问题。
55#
 楼主| 发表于 2023-1-9 15:35:45 | 只看该作者
Start server
2023/01/09 07:29:25.635        INFO        using provided configuration        {"confi ...
Caddyfile异常,在jjpssl附近,可以检查下是不是输入了什么异常字符
56#
发表于 2023-1-9 22:35:02 | 只看该作者
可以使用了,但是
使用v2RayN   连接
大概1分钟不到就会掉线,断了重新连接又可以了。但是1分钟又会断。
2023/01/09 22:23:53 [Warning] core: Xray 1.7.0 started
2023/01/09 22:28:13 [Warning] [2244166683] app/proxyman/outbound: failed to process outbound traffic > proxy/socks: failed to establish connection to server > read tcp 127.0.0.1:1867->127.0.0.1:1080: i/o timeout
2023/01/09 22:28:15 [Warning] [221933857] app/proxyman/outbound: failed to process outbound traffic > proxy/socks: failed to establish connection to server > read tcp 127.0.0.1:1869->127.0.0.1:1080: i/o timeout
2023/01/09 22:28:20 [Warning] [831127675] app/proxyman/outbound: failed to process outbound traffic > proxy/socks: failed to establish connection to server > read tcp 127.0.0.1:1872->127.0.0.1:1080: i/o timeout
2023/01/09 22:28:23 [Warning] [3006064210] app/proxyman/outbound: failed to process outbound traffic > proxy/socks: failed to establish connection to server > read tcp 127.0.0.1:1874->127.0.0.1:1080: i/o timeout
2023/01/09 22:28:42 [Warning] [1522382230] app/proxyman/outbound: failed to process outbound traffic > proxy/socks: failed to establish connection to server > read tcp 127.0.0.1:1878->127.0.0.1:1080: i/o timeout
2023/01/09 22:28:42 [Warning] [1522382230] proxy/http: failed to read response from www.gstatic.com > io: read/write on closed pipe
2023/01/09 22:28:46 [Warning] [4069559797] app/proxyman/outbound: failed to process outbound traffic > proxy/socks: failed to establish connection to server > read tcp 127.0.0.1:1881->127.0.0.1:1080: i/o timeout
2023/01/09 22:28:51 [Warning] [2957544304] app/proxyman/outbound: failed to process outbound traffic > proxy/socks: failed to establish connection to server > read tcp 127.0.0.1:1885->127.0.0.1:1080: i/o timeout
2023/01/09 22:28:52 [Warning] [4118445812] app/proxyman/outbound: failed to process outbound traffic > proxy/socks: failed to establish connection to server > read tcp 127.0.0.1:1887->127.0.0.1:1080: i/o timeout
57#
 楼主| 发表于 2023-1-10 00:24:54 | 只看该作者
HKCPC 发表于 2023-1-9 22:35
可以使用了,但是
使用v2RayN   连接
换个socks端口试试看,我用1080好像容易出问题
58#
发表于 2023-1-10 04:19:02 | 只看该作者
发表于 2023-1-10 22:37:11 | 只看该作者
换了1090 10800一样的问题,都是只能连接一分钟左右
60#
发表于 2023-1-12 19:45:51 | 只看该作者
输入docker logs -f naiveproxy
出现 Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
docker的问题,守护进程不在运行状态,https://stackoverflow.com/questions/44678725/cannot-connect-to-the-docker-daemon-at-unix-var-run-docker-sock-is-the-docker  发表于 2023-1-12 22:32
GMT+8, 2026-4-15 13:39 , Processed in 0.061696 second(s), 8 queries , Gzip On, MemCache On.
