123
返回列表 发新帖
楼主: 孜枫
[Windows VPS] 奇怪,pptp的vpn一键安装包安装以后
 楼主| 发表于 2012-3-8 11:50:49 | 只看该作者
Mar  7 11:28:41 wcj pptpd[2399]: MGR: connections limit (100) reached, extra IP addresses ignored
Mar  7 11:28:41 wcj pptpd[2401]: MGR: Manager process started
Mar  7 11:28:41 wcj pptpd[2401]: MGR: Maximum of 100 connections available
Mar  7 11:34:02 wcj kernel: Removing netfilter NETLINK layer.
Mar  7 11:34:12 wcj pptpd[2704]: CTRL: Client 123.119.83.131 control connection started
Mar  7 11:34:12 wcj pptpd[2704]: CTRL: Starting call (launching pppd, opening GRE)
Mar  7 11:34:12 wcj pppd[2705]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded.
Mar  7 11:34:12 wcj kernel: CSLIP: code copyright 1989 Regents of the University of California
Mar  7 11:34:12 wcj kernel: PPP generic driver version 2.4.2
22#
 楼主| 发表于 2012-3-8 11:51:36 | 只看该作者
Mar  7 11:34:12 wcj pppd[2705]: pppd 2.4.4 started by root, uid 0
Mar  7 11:34:12 wcj pppd[2705]: Using interface ppp0
Mar  7 11:34:12 wcj pppd[2705]: Connect: ppp0 <--> /dev/pts/2
Mar  7 11:34:13 wcj pptpd[2704]: CTRL: Ignored a SET LINK INFO packet with real ACCMs!
Mar  7 11:34:13 wcj kernel: PPP MPPE Compression module registered
Mar  7 11:34:14 wcj pppd[2705]: MPPE 128-bit stateless compression enabled
Mar  7 11:34:16 wcj pppd[2705]: Cannot determine ethernet address for proxy ARP
Mar  7 11:34:16 wcj pppd[2705]: local  IP address 172.16.36.1
Mar  7 11:34:16 wcj pppd[2705]: remote IP address 172.16.36.2
Mar  7 11:37:11 wcj pppd[2705]: LCP terminated by peer (^OM-3^UM-b^@<M-Mt^@^@^@^@)
Mar  7 11:37:11 wcj pppd[2705]: Connect time 3.0 minutes.
Mar  7 11:37:11 wcj pppd[2705]: Sent 0 bytes, received 77876 bytes.
Mar  7 11:37:11 wcj pppd[2705]: Modem hangup
Mar  7 11:37:11 wcj pppd[2705]: Connection terminated.
Mar  7 11:37:11 wcj pppd[2705]: Exit.
Mar  7 11:37:11 wcj pptpd[2704]: CTRL: Client 123.119.83.131 control connection finished
Mar  7 11:43:00 wcj pptpd[2935]: CTRL: Client 123.119.83.131 control connection started
Mar  7 11:43:00 wcj pptpd[2935]: CTRL: Starting call (launching pppd, opening GRE)
Mar  7 11:43:00 wcj pppd[2936]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded.
Mar  7 11:43:00 wcj pppd[2936]: pppd 2.4.4 started by root, uid 0
Mar  7 11:43:00 wcj pppd[2936]: Using interface ppp0
Mar  7 11:43:00 wcj pppd[2936]: Connect: ppp0 <--> /dev/pts/2
Mar  7 11:43:03 wcj pptpd[2935]: CTRL: Ignored a SET LINK INFO packet with real ACCMs!
Mar  7 11:43:04 wcj pppd[2936]: MPPE 128-bit stateless compression enabled
Mar  7 11:43:06 wcj pppd[2936]: Cannot determine ethernet address for proxy ARP
Mar  7 11:43:06 wcj pppd[2936]: local  IP address 172.16.36.1
Mar  7 11:43:06 wcj pppd[2936]: remote IP address 172.16.36.2
Mar  7 11:46:09 wcj pppd[2936]: LCP terminated by peer (!S~M-=^@<M-Mt^@^@^@^@)
Mar  7 11:46:09 wcj pppd[2936]: Connect time 3.1 minutes.
Mar  7 11:46:09 wcj pppd[2936]: Sent 0 bytes, received 85589 bytes.
Mar  7 11:46:10 wcj pppd[2936]: Modem hangup
Mar  7 11:46:10 wcj pppd[2936]: Connection terminated.
Mar  7 11:46:10 wcj pppd[2936]: Exit.
Mar  7 11:46:10 wcj pptpd[2935]: CTRL: Client 123.119.83.131 control connection finished
Mar  7 11:53:49 wcj kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Mar  7 11:53:49 wcj kernel: Netfilter messages via NETLINK v0.30.
Mar  7 11:53:49 wcj kernel: ip_conntrack version 2.4 (8192 buckets, 65536 max) - 304 bytes per conntrack
Mar  7 12:19:32 wcj kernel: Removing netfilter NETLINK layer.
Mar  7 12:19:32 wcj kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Mar  7 12:19:32 wcj kernel: Netfilter messages via NETLINK v0.30.
Mar  7 12:19:32 wcj kernel: ip_conntrack version 2.4 (8192 buckets, 65536 max) - 304 bytes per conntrack
Mar  7 12:21:05 wcj kernel: Removing netfilter NETLINK layer.
Mar  7 12:21:05 wcj kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Mar  7 12:21:05 wcj kernel: Netfilter messages via NETLINK v0.30.
Mar  7 12:21:05 wcj kernel: ip_conntrack version 2.4 (8192 buckets, 65536 max) - 304 bytes per conntrack
Mar  7 12:23:20 wcj pptpd[4260]: MGR: Maximum of 100 connections reduced to 20, not enough IP addresses given
Mar  7 12:23:20 wcj pptpd[4261]: MGR: Manager process started
Mar  7 12:23:20 wcj pptpd[4261]: MGR: Maximum of 20 connections available
23#
 楼主| 发表于 2012-3-8 11:58:05 | 只看该作者
继续等。
24#
 楼主| 发表于 2012-3-8 13:07:32 | 只看该作者
ding
25#
 楼主| 发表于 2012-3-8 15:15:39 | 只看该作者
26#
发表于 2012-3-8 15:23:38 | 只看该作者
 楼主| 发表于 2012-3-8 16:31:16 | 只看该作者
看来解决不了了。
GMT+8, 2026-4-15 23:00 , Processed in 0.058732 second(s), 9 queries , Gzip On, MemCache On.
