123
返回列表 发新帖
楼主: Corei7
[日本VPS] Virmach东京锐龙单核352多核299破上次记录
 楼主| 发表于 2022-7-2 23:58:04 | 只看该作者
记录
更新 20220702
  1. Geekbench 5 Benchmark Test:
  3. Test            | Value
  4.                 |
  5. Single Core     | 772
  6. Multi Core      | 1390
  7. Full Test       | https://browser.geekbench.com/v5/cpu/15785306
22#
发表于 2022-7-3 00:14:33 | 只看该作者
真离谱啊就
23#
发表于 2022-7-4 15:20:37 | 只看该作者
CPU Model          : Intel(R) Xeon(R) CPU E5-2670 v2 @ 2.50GHz
CPU Cores          : 2 @ 2499.998 MHz
CPU Cache          : 4096 KB
AES-NI             : Enabled
VM-x/AMD-V         : Disabled
Total Disk         : 14.5 GB (2.9 GB Used)
Total Mem          : 2.0 GB (140.8 MB Used)
Total Swap         : 256.0 MB (0 Used)
System uptime      : 5 days, 0 hour 45 min
Load average       : 0.07, 0.02, 0.00
OS                 : Ubuntu 16.04.7 LTS
Arch               : x86_64 (64 Bit)
Kernel             : 4.11.8-041108-generic
TCP CC             : bbr
Virtualization     : KVM
Organization       : AS36352 ColoCrossing
Region             : California
I/O Speed(1st run) : 8.3 MB/s
^C
服了 io 8M/s 。。。。
24#
 楼主| 发表于 2022-7-18 17:42:32 | 只看该作者
记录
更新 20220718
  3. #                     v2022-06-11                    #
  6. Mon 18 Jul 2022 05:32:14 AM EDT
  7. Basic System Information:
  9. Uptime     : 24 days, 7 hours, 27 minutes
  10. Processor  : AMD Ryzen 9 5900X 12-Core Processor
  11. CPU cores  : 2 [url=home.php?mod=space&uid=175]@[/url] 3693.062 MHz
  12. AES-NI     : ✔ Enabled
  13. VM-x/AMD-V : ✔ Enabled
  14. RAM        : 1.9 GiB
  15. Swap       : 975.0 MiB
  16. Disk       : 38.1 GiB
  17. Distro     : Debian GNU/Linux 11 (bullseye)
  18. Kernel     : 5.18.3
  19. fio Disk Speed Tests (Mixed R/W 50/50):
  20. ---------------------------------
  21. Block Size | 4k            (IOPS) | 64k           (IOPS)
  22.   ------   | ---            ----  | ----           ----
  23. Read       | 263.31 MB/s  (65.8k) | 159.65 MB/s   (2.4k)
  24. Write      | 264.00 MB/s  (66.0k) | 160.49 MB/s   (2.5k)
  25. Total      | 527.31 MB/s (131.8k) | 320.15 MB/s   (5.0k)
  26.            |                      |
  27. Block Size | 512k          (IOPS) | 1m            (IOPS)
  28.   ------   | ---            ----  | ----           ----
  29. Read       | 2.94 GB/s     (5.7k) | 4.06 GB/s     (3.9k)
  30. Write      | 3.10 GB/s     (6.0k) | 4.33 GB/s     (4.2k)
  31. Total      | 6.05 GB/s    (11.8k) | 8.40 GB/s     (8.2k)
  32. Geekbench 5 Benchmark Test:
  33. ---------------------------------
  34. Test            | Value
  35.                 |
  36. Single Core     | 1146
  37. Multi Core      | 2149
  38. Full Test       | https://browser.geekbench.com/v5/cpu/16082425
  3. #                     v2022-06-11                    #
  11. CPU cores  : 2 @ 3693.062 MHz
  14. RAM        : 1.9 GiB
  16. Disk       : 38.1 GiB
  18. Kernel     : 5.18.3
  19. -------------------- A Bench.sh Script By Teddysun -------------------
  20. Version            : v2022-06-01
  21. Usage              : wget -qO- bench.sh | bash
  22. ----------------------------------------------------------------------
  23. CPU Model          : AMD Ryzen 9 5900X 12-Core Processor
  24. CPU Cores          : 2 @ 3693.062 MHz
  25. CPU Cache          : 512 KB
  26. AES-NI             : Enabled
  27. VM-x/AMD-V         : Enabled
  28. Total Disk         : 38.1 GB (2.7 GB Used)
  29. Total Mem          : 1.9 GB (272.8 MB Used)
  30. Total Swap         : 975.0 MB (780.0 KB Used)
  31. System uptime      : 24 days, 7 hour 38 min
  32. Load average       : 0.09, 0.15, 0.14
  33. OS                 : Debian GNU/Linux 11
  34. Arch               : x86_64 (64 Bit)
  35. Kernel             : 5.18.3
  36. TCP CC             : bbr
  37. Virtualization     : KVM
  38. Organization       : AS23959 Owl Limited
  39. Location           : Tokyo / JP
  40. Region             : Tokyo
  41. ----------------------------------------------------------------------
  42. I/O Speed(1st run) : 617 MB/s
  43. I/O Speed(2nd run) : 869 MB/s
  44. I/O Speed(3rd run) : 1.0 GB/s
  45. I/O Speed(average) : 836.7 MB/s
  46. ----------------------------------------------------------------------
  47. Node Name        Upload Speed      Download Speed      Latency
  48. Speedtest.net    469.56 Mbps       868.54 Mbps         2.41 ms
  49. Los Angeles, US  545.89 Mbps       429.23 Mbps         109.35 ms
  50. Dallas, US       441.41 Mbps       375.04 Mbps         137.16 ms
  51. Montreal, CA     432.87 Mbps       453.31 Mbps         166.68 ms
  52. Paris, FR        328.68 Mbps       410.31 Mbps         231.04 ms
  53. Amsterdam, NL    339.36 Mbps       520.18 Mbps         236.42 ms
  54. Shanghai, CN     564.36 Mbps       536.71 Mbps         139.37 ms
  55. Nanjing, CN      801.08 Mbps       620.17 Mbps         35.49 ms
  56. Hongkong, CN     552.40 Mbps       920.44 Mbps         117.85 ms
  57. Seoul, KR        745.52 Mbps       713.81 Mbps         61.28 ms
  58. Singapore, SG    720.85 Mbps       651.58 Mbps         68.01 ms
  59. Tokyo, JP        887.55 Mbps       820.68 Mbps         1.04 ms
  60. ----------------------------------------------------------------------
  61. Finished in        : 5 min 44 sec
  62. Timestamp          : 2022-07-18 05:48:42 EDT
  63. ----------------------------------------------------------------------
25#
发表于 2022-7-18 17:44:01 | 只看该作者
Corei7 发表于 2022-7-18 17:42
记录
更新 20220718
驯龙高手放弃缰绳了?
GMT+8, 2026-4-17 04:48 , Processed in 0.060835 second(s), 7 queries , Gzip On, MemCache On.
