123
返回列表 发新帖
楼主: 明昆
[疑问] 这是哪个大佬的站,求源码,太喜欢了
发表于 2022-5-18 01:22:04 来自手机 | 只看该作者
etc小号 发表于 2022-5-18 01:19
花了点时间克隆了下,还挺简单的
html直接用它的,php的api自己写一下,图片换自己的,ok完事
大佬,nb,源码呢?(。>∀<。)
22#
发表于 2022-5-18 01:33:46 | 只看该作者
KuYeHQ 发表于 2022-5-18 01:22
大佬,nb,源码呢?(。>∀
我这是换了自己的图片,自己搭建的话得换成自己的,我这可以给html和php的源码借鉴一下
这是html的
http://mm.hostloc.ltd/vm/vm.tar.gz
这是php的
  1. <?php
  2. header('Content-Type:application/json; charset=utf-8');
  3. $f='1.txt'; //文件名
  4. $a=file($f); //把文件的所有内容获取到数组里面
  5. $n=count($a); //获得总行数
  6. $rnd=rand(0,$n); //产生随机行号
  7. $rnd_line=$a[$rnd]; //获得随机行
  8. echo "$rnd_line"; //显示结果
  9. ?>
把标题和图片以json的形式写入txt
格式类似这样
  1. {"title":"ROSI NO.2354 Flesh-Colored Pantyhose","imgs":["https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/d.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-001.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-002.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-003.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-004.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-005.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-006.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-007.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-008.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-009.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-010.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-011.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-012.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-013.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-014.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-015.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-016.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-017.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-018.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-019.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-020.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-021.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-022.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-023.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-024.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-025.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-026.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-027.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-028.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-029.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-030.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-031.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-032.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-033.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-034.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-035.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-036.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-037.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-038.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-039.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-040.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-041.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-042.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-043.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-044.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-045.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-046.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-047.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-048.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-049.webp","https:\/\/www.1y.is\/wp-content\/uploads\/rosi_webp\/NO.2354\/rosi-2354-050.webp"]}
23#
 楼主| 发表于 2022-5-18 08:43:38 | 只看该作者
这是html的
大佬牛逼
可以实现自动获取文件内所有 子文件夹 及 子文件 名称不。
这就可以把爬来的图包解压放进去进行了。
手动获取和转换格式有些麻烦。
24#
发表于 2022-5-18 08:56:46 | 只看该作者
战略性mark。留着备用
25#
发表于 2022-5-18 11:30:36 | 只看该作者
明昆 发表于 2022-5-18 08:43
大佬牛逼
这就可以把爬来的图包解压放进去进行 ...
我就是手动的,把之前爬的图片站链接写入文本,然后手动转成json
我估计这个原作者肯定不是这样搞得,我这是笨办法,他估计json是php生成的,不是向我这样从文本读取的
但是没办法,我不懂代码
27#
发表于 2022-5-18 15:37:32 | 只看该作者
上哪下载这些套路,看着怪来劲
GMT+8, 2026-4-21 05:36 , Processed in 0.060896 second(s), 9 queries , Gzip On, MemCache On.
