楼主: Tong
RN 1c 1g 8t 完整数据!(流量已翻倍)
 楼主| 发表于 2022-4-20 17:06:06 | 只看该作者
jhu 发表于 2022-4-20 16:28
你的CPU竟然有560分,我的3C的单核才399分。多核才1000分。
俺的也500多,哈哈
22#
发表于 2022-4-20 17:09:48 | 只看该作者
  1. LemonBench Server Test Tookit 20201005 Intl BetaVersion (C)iLemonrain. All Rights Reserved.
  2. ==========================================================================================
  3. [Info] Bench Start Time: 2022-04-20 17:04:12
  4. [Info] Test Mode: Fast Mode
  5. -> System Information
  6. OS Release:            Debian GNU/Linux "Sid (Testing)" 11.3 (x86_64)
  7. CPU Model:             Intel(R) Xeon(R) CPU E5-2680 v2 [url=home.php?mod=space&uid=175]@[/url] 2.80GHz  2.80 GHz
  8. CPU Cache Size:        16384 KB
  9. CPU Number:            2 vCPU
  10. Virt Type:             KVM
  11. Memory Usage:          175.66 MB / 2.43 GB
  12. Swap Usage:            0 KB / 975.00 MB
  13. Boot Device:           /dev/vda1
  14. Disk Usage:            1.69 GB / 19.48 GB
  15. CPU Usage:             3.1% used, 0.0% iowait, 0.0% steal
  16. Load (1/5/15min):      2.16 0.56 0.19
  17. Uptime:                0 Days, 1 Hours, 53 Minutes, 22 Seconds
  18. Kernel Version:        5.17.1
  19. Network CC Method:     bbr + fq_pie
  20. -> Network Infomation
  21. -> Media Unlock Test
  22. HBO Now:                               Yes
  23. Bahamut Anime:                         No
  24. Abema.TV:                              No
  25. Princess Connect Re:Dive Japan:        No
  26. BBC:                                   No
  27. BiliBili China Mainland Only:          No
  28. BiliBili Hongkong/Macau/Taiwan:        No
  29. Bilibili Taiwan Only:                  No
  30. -> CPU Performance Test (Fast Mode, 1-Pass @ 5sec)
  31. 1 Thread Test:                 922 Scores
  32. 2 Threads Test:                1792 Scores
  33. -> Memory Performance Test (Fast Mode, 1-Pass @ 5sec)
  34. 1 Thread - Read Test :         19046.96 MB/s
  35. 1 Thread - Write Test:         17035.92 MB/s
  36. -> Disk Speed Test (4K Block/1M Block, Direct Mode)
  37. Test Name              Write Speed                             Read Speed
  38. 100MB-4K Block         44.5 MB/s (0.09 IOPS, 2.36s))           52.4 MB/s (12782 IOPS, 2.00s)
  39. 1GB-1M Block           1.8 GB/s (1710 IOPS, 0.58s)             1.1 GB/s (1006 IOPS, 0.99s)
  40. -> Speedtest.net Network Speed Test
  41. Node Name                      Upload Speed    Download Speed  Ping Latency    Server Name
  42. Speedtest Default              100.86 MB/s     111.38 MB/s     52.69 ms        Frontier (United States Chicago, IL)
  43. China, Beijing CU              Fail: Timeout Exceeded after 60 seconds
  44. China, Shanghai CT             25.62 MB/s      56.25 MB/s      127.26 ms       China Telecom (China Shanghai)
  45. China, Hangzhou CM             Fail: Timeout Exceeded after 60 seconds
  46. ==========================================================================================
  47. [Info] Bench Finish Time: 2022-04-20 17:05:51
  48. [Info] Time Elapsed: 99 seconds
23#
发表于 2022-4-20 17:11:18 | 只看该作者
对移动不太友好的样子
下载速度19.25Mbps 上传速度21.07Mbps 延迟182.55ms 抖动1.11ms
24#
 楼主| 发表于 2022-4-20 17:11:39 | 只看该作者
这个上传在干嘛
25#
发表于 2022-4-20 17:12:14 | 只看该作者
哪家的鸡?cloudcone吗
26#
 楼主| 发表于 2022-4-20 17:18:55 | 只看该作者
adrce 发表于 2022-4-20 17:11
对移动不太友好的样子
下载速度19.25Mbps 上传速度21.07Mbps 延迟182.55ms 抖动1.11ms ...
确实,目前看来移动的速度最快的江苏南京,88Mbps
27#
发表于 2022-4-20 17:20:14 | 只看该作者
woputby 发表于 2022-4-20 17:12
哪家的鸡?cloudcone吗
RN的圣何塞,昨天测的。24.28那款,3c3g45g
28#
发表于 2022-4-20 17:20:22 | 只看该作者
对移动不太友好的样子
移动   RN 只能买LA 其他都不太行。。。
30#
发表于 2022-4-20 17:22:10 | 只看该作者
你可以空闲时再测一次看看
GMT+8, 2026-4-23 23:14 , Processed in 0.061600 second(s), 8 queries , Gzip On, MemCache On.
