楼主: dwcloud
[疑问] VIR 这是啥意思?日了dog
发表于 2022-4-24 11:20:44 | 只看该作者
8。88两年付?是不是没5900x了,不给你开机
发表于 2022-4-24 11:23:43 来自手机 | 只看该作者
我还以为就我一个是这样。。。
发表于 2022-4-24 11:24:22 | 只看该作者
再从母鸡里给你焯一台不就完事了
发表于 2022-4-24 11:24:48 来自手机 | 只看该作者
发表于 2022-4-24 11:26:05 | 只看该作者
Tuzi 发表于 2022-4-24 11:24
再从母鸡里给你焯一台不就完事了
老板技术不到家,再超就崩了
发表于 2022-4-24 11:26:19 | 只看该作者
昨天新开给了我38节点,一直offline
发表于 2022-4-24 14:04:38 来自手机 | 只看该作者
不会是因为工单催过被老板针对了吧
 楼主| 发表于 2022-4-24 14:05:23 | 只看该作者
minota 发表于 2022-4-24 14:04
不会是因为工单催过被老板针对了吧
我根本就没催过 从来没有过,所以我很无语
发表于 2022-4-24 14:25:51 | 只看该作者
Tokyo should be at 100% right now but I found another problem earlier today or last night, a lot of what we call "zombies" created. This is a bug with WHMCS provisioning module and/or SolusVM that dates back to several years ago and still going strong (not fixed by anyone.) It causes VMs to create duplicates of themselves sometimes. So there's a good amount of these that threw off our estimates by around 200 VMs.
This means we're short by around 200 VMs and it doesn't help that TYOC038 has a missing disk as well as one or two others. We need to schedule maintenance to add new disks to these to finish off the rest, but I'm still trying to fit as many of these as we can here and there.
We need to do a cleanup of these "zombies" or duplicates to make more room but that will take a few days. We have to do them in a way where we don't just immediately terminate them just in case someone is for some reason using the duplicate service instead of the primary one.
The perks of using 10 year old PHP software!
早上回复的,好像是有软件问题导致一批人没成功开机,需要再等等
20#
 楼主| 发表于 2022-4-24 19:10:02 | 只看该作者
莉莉丝 发表于 2022-4-24 14:25
Tokyo should be at 100% right now but I found another problem earlier today or last night, a lot of  ...
听他扯,我这个应该是3月29号就这样了...
GMT+8, 2026-4-18 18:50 , Processed in 0.070633 second(s), 9 queries , Gzip On, MemCache On.
